configure ospfv3 area normal
configure ospfv3 area area_identifier normal
Description
Configures an OSPFv3 area as a normal area.
Syntax Description
area_identifier Specifies an OSPFv3 area, a four-byte, dotted decimal number.
Default
Normal.
Usage Guidelines
A normal area is an area that is not any of the following:
  • Stub area
  • NSSA
Virtual links can be configured through normal areas. External routes can be distributed into normal areas.
The following command configures an OSPFv3 area as a normal area:
configure ospfv3 area 10.1.0.0 normal
Platform Availability
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
